Mode vi return NaN
I am using the mode function to calculate the mode value of an array and it returns NaN. LabVIEW help says it only returns NaN when array input is empty. I am not sure why this happen. My array is
0.00015
0.000114
0.000146
0.000188
0.000139
I did try with mulitple value of intervals.
Thanks in advance.
(6,066 Views)
I think your number of intervals needs to be less than or equal to the input array size.
If you set it to a negative number then it should always return the most commonly occuring value instead of using bins.
(6,057 Views)
Kyle97330,
I have just tried to use -1 but it is still does not work.
I am not sure NaN means it cannot find the repeat value or not.
(6,005 Views)
Accepted by NTT
NaN in this case means that no mode was found.  Look at it this way... you have a group of numbers and are telling LabVIEW to break it up into 1000 separate "bins". If each bin has only 1 value in it, then there is no mode - no single value that appears more often than other values.
For your data set, any number of intervals < = 14 will return a mode.  Any > 15 will return NaN.
(5,998 Views)
Hi NTT,
For interval = [1, 10] it works nicely - means it gives an output different to NaN…
(5,992 Views)
Thanks Bowen,
Actually I have just found out the answer by using the historgram. It illustrated the reason very clear to me.
(5,991 Views)
Thanks Gred, I got this now.
(5,969 Views)
