Modification to Write Configuration .ini file
@RavensFan wrote:
This was something that was changed in the Config Files behavior, sometime before 2013.  I want to say it was quite a few years back.  I'll guess around LV 2009, but I don't specifically remember.
I happened with LabVIEW 2009.  If you upconvert some VIs from 8.6, you will see the deprecated VIs with their icons that show "8.6".
Message 11 of 12
(1,042 Views)
Yeah, it's been around as long as i can remember, who started with LV professionally with 8.2. (i'm pretty sure it's present there)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 12
(1,010 Views)
