Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Modifications Bitset Bug
Re: Modifications Bitset Bug
jpeters
Member
04-04-2007
12:16 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I think I found our confusion. I was running 8.2 and the behavior has changed!
In fact, I have confirmed that this is a bug in 7.1, but seems fixed in 8.2
Good catch.
0
Kudos
Message
11
of 13
(962 Views)
Reply
Jaegen
Member
Author
04-04-2007
12:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for this.
Could you clarify a bit? Does "Ignore Errors inside Node" not work at all for 7.1, or just for these properties?
Jaegen
0
Kudos
Message
12
of 13
(959 Views)
Reply
jpeters
Member
04-04-2007
12:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I can't say that I know the full scope of the problem, but it seems to happen in this VI also. So if I had to guess, the feature Ignore Errors... doesn't seem to work properly in 7.1
simpleignoretest.vi 18 KB
0
Kudos
Message
13
of 13
(953 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
