Modifying HL_Triggered_Grab for using PLC tags as trigger
    I am using a NI1752 smart camera.  I would like to trigger it using a PLC tag value.  On the forums, it was suggested to modify the HL_Triggered_Grab example.  I have some doubt in the example.
a) In the IMAQ property node, the boolean value from the control is set to a property named 'Send Software Trigger'.  I cannot find such a property in the list.  Am I understanding it wrongly?  I have attached a screen shot.
b) What is the trigger line number?  How do I set up the trigger for PLC tag ?
I am accessing the tag value using OPC client.  If someone could tell me how to modify that example, it would be of great help.
Best,
Gibin
(3,946 Views)
Hi Gibin,
You need to use the TrigIn/IsoIn(0)+ andTrigIn/IsoIn(0)- inputs to trigger an acquisition.
NI 17xx Smart Camera User Manual and Specifications
http://www.ni.com/pdf/manuals/372429c.pdf
Could you attach the example? I can't find it in my system, and finding it would be useful to help you troubleshoot.
Best,
Rey
(3,871 Views)
Hi Rey,
    Thanks for the reply.  I believe that the TrigIn/IsoIn(0)+ andTrigIn/IsoIn(0)- inputs are for hardware trigger.  I would like to make a software trigger which can be triggered from a VI on the host system.
Best,
Gibin
(3,869 Views)
Again, could you attach the example? It would be useful in order to help you troubleshoot.
-Rey
(3,863 Views)
    I have attached the vi.  I am not able to see the shared variables on the NI distributed systems manager also.  I get the following error message.
I believe this is the error when firewall settings are not matching.  I dont know how to solve this.  Would appreciate any help.
Best,
Gibin Joe
Best,
Gibin Joe
(3,855 Views)
Joe,
Have you already tried the steps in the KB below? I looked over the code, and can't find any glaring issues.
Warning -1950679034 when Reading a Shared Variable
http://digital.ni.com/public.nsf/allkb/238D4F85D7EF6A0F86257536006F7718
(3,848 Views)
