Modifying Pane Origin doesn't affect scrolling.
I'm trying to make an application that allows a user to modify the screen size and still be able to control everything. Most of this is done by having a main vi that has subpanels that get filled up with vi's. All of this is built upon actor framework.
I don't want any elements on the front panel of all the vi's to change size. The only thing I want is for the position of the vi within the subpanel to change so that it is always centered. I've achieved this by taking the size of a Pane, and setting the origin to the center based on the rectangular area of all the controls. This part works great. I programmatically turn on the scroll bars if the vi won't fit in the subpanel so the user can still get to everything.
The problem comes when a user uses the scrollbar on a subpanel. Since the inserted vi is centered, because of the origin change, I would hope the scroll bar would take that modified origin and change it. Instead it seems like whenever I use the scrollbar it takes the default origin, instead of the one I set. This causes my vi's within subpanels to be thrown to one side of the window, instead of remaining center. You can see that behavior in the gif I attached. Example.gif
Anybody ever ran into this issue and know a way around it?
(3,426 Views)
I've look up some methods in property nodes that could help you:
-Property nodes: VI server class
                              >Keep window proportions
                              >Panel Bounds
                              >Window Bounds
                              >Resizable
If you are not going to set other controls or indicators in your front panel you could set a specific window size to prevent the reference problem. By the way, you can always look up for the functions of these methods on the web.
Hope this help you.
(3,315 Views)
Zip file of example code
(3,291 Views)
HI ShockHouse,
Thanks for pointing this out. I filed a BUG report for you (our new system instead of CARs) the BUG number is 264279
I hope you have a great weekend!
Zofia
NI Technical Support Engineer
(3,262 Views)
