06-23-2020 07:41 AM
I create VI on Win 10 and create exe application. Everything looks good on same PC.
But when I run it on some other PC with win7 or win10, arrays are moved from original position.
Please check attachment.
Can someone advise how to solve this.
Thanks.
Solved! Go to Solution.
06-23-2020 08:02 AM
Hi Milan,
you need to use/set the same font settings on both computers!
Using different fonts (or sizes) results in such (apparently) moved FP elements…
Easiest would be to include some additional keys in the EXE.ini, when you create an executable from your VI.
I usually include:
appFont="Tahoma" 13
dialogFont="Tahoma" 13
systemFont="Tahoma" 13
FPFont="Tahoma" 13
BDFont="Tahoma" 13
06-23-2020 08:56 AM
@GerdW wrote:
Hi Milan,
I usually include:
appFont="Tahoma" 13 dialogFont="Tahoma" 13 systemFont="Tahoma" 13 FPFont="Tahoma" 13 BDFont="Tahoma" 13
Similarly, I have the following in my executables' ini files
appFont="Segoe UI" 13
dialogFont="Segoe UI" 13
systemFont="Segoe UI" 13
returnKeyAction=True
I think the Segoe UI was the default Application Font with Windows 7. I haven't noticed any differences for Windows 10.
06-23-2020 12:13 PM
To explain what others have said, LabVIEW by default uses symbolic fonts, which will inherit their look from the OS theme and scaling. If a windows installation has font scaling that is not set at 100% or e.g. uses a gigantic, high contrast font for accessibility by the visually impaired, it will blow up the front panel in unpredictable ways.
Even if you define all fonts in your LabVIEW ini, symbolic fonts still sneak in occasionally. I always wanted a VI analyzer that will find all instances of symbolic fonts, It seems in LabVIEW 2020, it finally got implemented! (See picture. Haven't tested it in detail, though).
Reason enough for me to upgrade everything to 2020! 😄 I don't like modifying the <exe>.ini
06-24-2020 02:37 AM
Hello all,
thanks , you solve mystery and help me a lot.
Thanks again.
06-24-2020 05:15 AM
I put instrument settings and other parameters in there for almost every application. So I have absolutely no problem with modifying that ini file.
03-10-2021 12:57 PM
How did you get that window with those options? I'm using LV Pro 2020 SP1 32-bit and get this:
03-10-2021 02:56 PM
As explained in your other thread, Vi analyzer needs to be installed to get full functionality.
