Showing results forĀ
Search instead forĀ
Did you mean:Ā
Multi-Case-Structure
what is the best way to create an multi-case structure for checking many logic states in once? I need it for a simple state machine which is controlled by some digital sensors in the way:
WHEN DI0; DI2 = TRUE and DI1 and DI3 = FALSE then .........state1
WHEN DI0; DI3 = TRUE and DI2 and DI1 = FALSE then .........state2
WHEN all DI = TRUE then ........ error state
And so on... has someone an idea? Maybe I am a little bit slow?! šŸ˜‰
Thanks!
Paul
(4,062 Views)
You could build them into a 1D array of booleans, and then either convert to a number or to a string of 1s and 0s, such as in this thread.
That gives you either an integer or a string that can be input to a case structure condition and you can put in any logic states you require. Just remember to include a default state for unexpected combinations.
CLA
(4,053 Views)
try looking at this , once a number is connected to the case structure...right click and change "radix"
(4,014 Views)
How are you reading the DIO?  I would be tempted to just read the port (8 digital lines) as a U8 and then that value can go straight to the case selector.
The other option is to read the 3 lines as an array of booleans and then use Boolean Array To Number whose result can then go into the case selector.
If using numbers, you can set the radix of the case structure so that you can view the state case in boolean.  Might make it a little easier to understand what is happening.
(4,006 Views)
Yeah, the radix set to binary is the necessary part for me to improve readability of the case structure šŸ™‚
CLA
(3,996 Views)
