Multi signals acquisition from the same serial port
I'm doing a program so I can acquire 3 signals from an acquisition card by a serial port. With VISA I write a command " c01" to receive the signal with read VISA. I did it for one signal and It works. But for multiple signals, I found a way that is not very good. Because I can see a lot of spikes in the graph.
"c01" send this command to acquire signal from channel 1
"c02"  send this command to acquire signal from channel 2
"c03"  send this command to acquire signal from channnel 3
but the graphs are not correct.
here is attached the program i made.
Message 1 of 26
(3,752 Views)
Why are you using Bytes at Port in your communication scheme?
You are writing your command, then immediately checking Bytes at Port then reading that many.  Guess what?  You didn't give the device any time to return a response!
DON'T USE BYTES AT PORT!
What does a normal response look like?  Does it end in a termination character like a carriage return or linefeed?  Your VISA configure is setup to use a termination character as a linefeed.  If the response ends with a termination character, use it.
Get rid of Bytes at Port and make your VISA Read a large number of bytes, larger than the longest message you ever expect to receive.
Message 2 of 26
(3,747 Views)
I am receiving a string of 3 bytes in ASCII code. but I only need the first 2 bytes which are a voltage value between
0 and 4095 mV
instead of using "bytes at port" do I create a constant where I put the number of bytes.
In the end, I acquire an ECG signal with an amplitude of a few millivolts. I visualize three signals in parallel to observe it simultaneously. the Signals are not identical.
Message 3 of 26
(3,725 Views)
Yep.  I tend to use 50 or 100.  I would not set it to be 3 since that is how many bytes are supposedly in your message.  Considering an ASCII message format, that length could change on you.  So set it to be much larger to cover your bases.
GCentral
Message 4 of 26
(3,710 Views)
Why aren't you emphasizing this? Smiley Wink
GCentral
Message 5 of 26
(3,708 Views)
Larger font and in red?  I figured that'd be overkill.  Smiley Very Happy
Message 6 of 26
(3,704 Views)
I did it but it is getting worse. At first, I can receive the signals and visualize them in the graph even spikes. But now, it only acquires the data of the first command without showing any graphs.
Message 7 of 26
(3,682 Views)
I fixed the issue. I just needed to put the exact number of bytes "3". Because when I put a random number like 50 or 100 the read visa shows an error and it becomes very slow. so putting more bytes then you need can generate errors and slow the program.
When I put the right numbers of bytes it works great without spikes and very fast so I just added a "wait".
Thank you very much.
Best regards.
Message 8 of 26
(3,681 Views)
Hi sam,
You just need to follow the exact message format specs of your device! Setting the right TermChar might be much easier…
You read 3 bytes and convert the string to an array of bytes. Then you convert that array to a cluster of 9 elements (!?) to use Unbundle: why don't you just IndexArray the array elements? Much easier, simple, self-documenting, …
Why do you need to flush the VISA buffer?
Why do you need a sequence structure?
Why don't you use AutoCleanup?
Message 9 of 26
(3,678 Views)
=> Because I receive the data on ASCII format. So I convert it into bytes array to only use the first two bytes and convert it to decimal to read the voltage value.
=> So I empty it for the next commands
=>  to write the commands and read the signals respectively.
But I figure out that  I receive the same signal in the three graphs. So If you have a solution to read the three signals simultaneously it will help me a lot.
=> I don't know it, thank you for mention it. Is that a subVI ? i will try it
Message 10 of 26
(3,682 Views)
