Multiple cluster type def not updating
I'm fully on a phone today. A quick peek out my back door tells me why the power is out. I need a different type of wire slinger
where do they keep the black wires?
Message 21 of 28
(1,062 Views)
Easily scales to you buildings needs.
Ben
Message 22 of 28
(1,060 Views)
Great. now I just need two more. each 120 deg out of phase
Message 23 of 28
(1,051 Views)
I did it with 2011.
Kudos and Accepted as Solution are welcome!
Message 24 of 28
(1,040 Views)
@jyang72211 wrote:
I did it with 2011.
So I guess we are at a loss as to how this was accomplished. I don't know who originally said it but the phrase "a mystery wrapped in an enigma" seems to apply.
Take care,
Ben
Not knowing how the cluster was crated will make it hard or difficult to fix. Reminds me of yet another story...
WHen meeting my wife's parents for the first time I wa presented with a bit of a test. I was handed a glass brandy snifter that had the base of another snifter in it. I was asked to remove it without breaking it. No playing around with angles or bending ws possible since it would have broken the glass. I asked how did they get them together in the first place. I was told that they found them that way after running them through the dish washer. I walked to the sink ran hot water over the outer glass and after a short time the inner one slipped right out. I must have passed the test because they let me marry their daughter.
Message 25 of 28
(1,039 Views)
Hi Ben,
Nice story.  However, even if you figure out this problem, I have no daugther for you to marry :).  Nevertheless, a big pad on the shoulder awaits.
Message 26 of 28
(1,032 Views)
Well, I'm also not able to replicate that error. It seems that the VI itself must have become corrupt. You shouldn't be able to put a tab control in a cluster. So, I'm not surprised that it doesn't work.
Could you try remaking the VI without putting the tab control in the cluster? or just passing in the tab number and using that to control the tab control?
Applications Engineer
CLD Certified
Message 27 of 28
(1,016 Views)
I think I will just take out the tab controls from the cluster.  Thanks!
Message 28 of 28
(1,009 Views)
