Multiple instances of main VI(clones), need solution to seperate the FGV (SubVI) or its replacement
@Intaris wrote:
I would implement your FGV as a class (with your data as private data of the class) and pass the object wire around wherever you need it.
Each main VI creates its own version and from then on it's a wire. Implement DVR / accessors as needed.
Done.
I would second this approach.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 11
(300 Views)
