Multiple switches that control one function
I want to use four different switches to control one on/off control.  I have attached the VI I attempted, but instead of having any of the four switches able to be controlled, only the first switch is acting as a control, while the other three just are acting as indicators.
Thank you for any help or advice.
(4,560 Views)
This thread may help.
Ben
(4,553 Views)
Accepted by M. Bobby
Hi Bobby,
if you would move the text, that is placed infront of the switches, to the side, then you could also use switch2-4 again as controls!
Other option would be to set the controls to be in front of the text (there's an order button in the menu line...).
(4,549 Views)
I found that you have your lables infront of your control. If you move the labels behind the control it works. I added an event structure and it make the control a lot easier.
Tim
GHSP
(4,545 Views)
Thank you very much, I completely forgot that the text was in the way.
(4,543 Views)
