11-27-2009 09:08 AM - last edited on 03-03-2017 09:39 AM by karina.barles
Again presenting an issue that I know must be easily solvable and indeed I have graphs with multiple scales in a number of my applications with the additional scale swapped to the other side. Today, in completing the following to create a second X- or Y-axis, 'swap sides' is always grayed out on the right-click shortcut menu. I've clicked everywhere near the scale. Using LabVIEW 8.5. Any help is appreciated.
Adding Multiple X- and Y-Scales on Graphs or Charts Dim hasPlayer, playerversion hasPlayer = false playerversion = 10 Do While playerversion > 0 On Error Resume Next hasPlayer = (IsObject(CreateObject("ShockwaveFlash.ShockwaveFlash." & playerversion))) If hasPlayer = true Then Exit Do playerversion = playerversion - 1 Loop is_FlashVersion = playerversion is_Flash = hasPlayer
Complete the following steps to add a scale to a waveform graph or chart.
Solved! Go to Solution.
11-27-2009 10:16 AM - edited 11-27-2009 10:18 AM
Hi Don,
atleast with my LV8.6 I don't have any problems to create a 2nd scale and swap the side...
And LV8.5 is ok too!
Don't you think it would be better to not use white text on white background? ![]()
What other "code" have you copied into your post? Do you use other languages than LabVIEW on your development machine??? OMG ![]()
11-27-2009 11:02 AM
Hi Gerd -
I have no idea what happened regarding the cut and paste from LabVIEW Help in my post. Sorry about that.
If you can, can you provide a screenshot that shows me exactly where you right-clicked to get an ungrayed 'swap sides' option to appear in the right-click menu on the attached graph? I duplicated both the X and the Y scales. By the way, I rebooted my computer just to make sure something odd was not happenning, but I am still having the same problem.
Don
11-27-2009 11:07 AM
11-27-2009 11:51 AM
Right-clicking on scale numbers, 'Swap Sides' is still grayed. Does not matter which number or which scale. It is still grayed. This is a waveform graph. Anyone else have any thoughts on this?
11-27-2009 11:54 AM
Hi Don,
have you tried that with a new vi and a new Waveform graph?
Your pictures look a bit mangled as the duplicated scales are on top of the original one instead of next to each other. When this happens each time you create a new graph you should consider a fresh installation of LabVIEW
11-27-2009 11:58 AM
Hello Gerd:
Yes, I opened a new blank VI and placed on the front panel a new waveform graph. Yes, the new scales always appear directly on top of the old one, slightly offset. And this no matter how I resize the plot area. I don't know why.
I sure would prefer not to have to uninstall and reinstall LabVIEW.
Don
11-27-2009 12:11 PM
11-27-2009 12:21 PM
Hi Gerd - Unfortunately, same problem. Here is screenshot from your VI after I first deleted the second scale, then duplicated the Y-axis again...
11-27-2009 12:36 PM
Hi Don,
I don't meant to delete and recreate that scale.
Can you use my example as copy&paste source for your vis? This would be a way to postpone the fresh install of LV to some more days in the future
(Idea comes across: make a typedef from my control...)
