Multitable
had use for loop create origin multi table
want change multi index form 3 to 100
to ahieve modify multi table how to use for loop to achieve it
thanks a lots
(1,542 Views)
Accepted by ironaaron
Hi Aaron,
Both "tables" look like ordinary 2D arrays…
You just need to use ReplaceArraySubset to replace the 3rd row of the input array with a 1D array to achieve your desired output!
What have you tried and where are you stuck?
(1,533 Views)
You need to explain your terms ("multi table", "multi index", "origin"). (For example there is a program called origin, are you trying to interface?)
The index of an array element just points to a cell, it does not contain data that can be changed. You want to change the array value, not the index.
So please explain what you want to to. Where does the 2D array come from? Where does the new data row come from? Where does the result go? (and please don't tell us how it needs to be done. Most likely a FOR loop is not even needed!)
(1,496 Views)
