My computers are not in Network items of the shared variable
I am working with a laptop VAIO XP and a laptop HP Vista, I created a network and I can see both computers in both machines, I open the example Shared Variable Client-Server.lvproj in both computers and when I try to change the path of the shared variables I click browse and I dont see both computers on the VAIO only in the HP, I already desactivate both firewalls, and went to tools-shared variable-register computer and fix the IP, I tried all that but the same error keeps showing:
"Error 1950679022 ocurred at shared variable read in clients.lvlib: Data Item Binding Client.vi
Possible reasons:
labview:(Hex0x8BBB012) The process was not found or is not responding.
This warning ocurred while reading (\\.\client\bound waveform) "
I changed the path manualy on the bound variables typing the name of my computer and then the IP but it does not work either.
\\HP1\server\waveform
\\192.168.0.3\server\waveform
Message 1 of 10
(4,671 Views)
Is the "National Instruments Variable Engine" service running on all machines?
Message 2 of 10
(4,663 Views)
Could you explain how could I know that?
Message 3 of 10
(4,646 Views)
What version of LV are you using?
Is this the URL to your shared variable? Or are those two different URLs?
If this is a single URL to the shared variable you want to bind to, this is an invalid one.....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 4 of 10
(4,637 Views)
Hi I have LV 8.5 one machine is 192.168.0.2 and the other is 192.18.0.3, i could use de VAIO as a server but not as a client that is when I receive the error.
Message 5 of 10
(4,626 Views)
Maybe your user rights on the Vaio laptop are not sufficient?
Norbert
Norbert
Expert: Geometry
Message 6 of 10
(4,623 Views)
Right-click "My Computer", Left-click on "Manage."  On the left hand side of the window that comes up, click on "Services."
Message 7 of 10
(4,611 Views)
Lanazuly
Did you ever find a solution to this problem? I am having a similar issue at the moment, in that I cannot browse for variables on the Network. It only shows <No items>.
Message 8 of 10
(4,067 Views)
Have you tried under Tools >> Shared Variable the Register Computer option on the PC where you are trying to look for the other PCs.  If you try to register those other PCs, I think they'd start showing up for you.
Message 9 of 10
(4,046 Views)
The OPC server I'm hosting is on the same PC. When I open up the Distributed System Manager, I cannot see the OPC server on either the network or the localhost.
Message 10 of 10
(4,033 Views)
