New PXI-8360 module is not being recognized by MAX or device manager
I recently installed a new PXI-8360 control module on my older PXI-1031 chassis.  I used the software that was included to complete the activation for controlling my instruments through my laptop computer.  However, when I try to use the instruments, they are not showing up under the MAX devices.  The green lights on the module are illuminated indicating that it has power and it is linked to my laptop, but the software is not recognizing it.  I'm not seeing it under my computer's device manager either.  Does anyone have an idea of what the issue is?  Thanks.
Message 1 of 16
(7,205 Views)
Hi JMJ09,
Which drivers have you installed onto your laptop? In order to recognise the PXI and its modules you will need an installation of the "PXI Platform Services" driver as well as installing the drivers for each of the different modules contained in your PXI. For the NI download page, click on this link.
Remember that the order of installation is important as well, so please install LabVIEW first, then any modules and toolkits, before the drivers; and don't plug in the PXI until then.
Hope this helps you out!
Tori
Student
Message 2 of 16
(7,197 Views)
I'm getting the same error.  I have a PXI 1042 and the PXI 8360 card is not showing up under MAX devices.  The yellow link light is not illuminated, but the power light is.  The green light on the host computer PCI card is also lit.  I've installed the necessary software from the installation DVD, and all of the drivers installed without any problem.  I've rebooted both systems a number of times, always turning the PXI 1042 device on first before the host PC.  What am I missing?
Message 3 of 16
(7,003 Views)
The issue I was having was with an old driver from a pxi-8310 that was installed previously.  When I upgraded to the 8360 it was not compatible with the old driver and wouldn't complete installation.  Deleting the old 8310 driver fixed the problem.  Hope this helps.
Message 4 of 16
(7,001 Views)
Same error, but I don't find the way to delete de NI PXI-8310 driver, it doesn't appear at National Instruments Software nor msiBlast.
The configuration I have is a PXI-1042 Chassis with a NI PXI 8360, MAX doesn't detect it.
The strange thing is that with a PXIe-1082 and a NI PXIe-8360, MAX succesfully detect it.
Running in Windows 7.
Any help will be deeply appreciated.
Message 5 of 16
(6,801 Views)
What version of the PXI Platform Services driver are you using? This is the driver that I would suggest trying to re-install if you are having problems.
Are you using the same computer with the PXIe-1082 and the PXI -1042?
Nathan Murphy
NI C Series Modules Product Manager with an expired CLA
Message 6 of 16
(6,775 Views)
I'm using the PXI Platform  Services 4.01.
It is the same computer, when connecting the PXIe-1082 everything works fine, but when I try to use the PXI-1042 MAX doesn't detect it.
Of course, I turn off computer, connect chassis, turn on chassis and then turn on computer, when changing between both chassis.
Thanks for your help.
Message 7 of 16
(6,769 Views)
I had a similar problem also.
Have you tried installing the mxi-express-bios-compatibility-software? See link below.
http://www.ni.com/download/mxi-express-bios-compatibility-software-1.5/3764/en/
This helped to solve my problem.
Cheers,
mcduff
Message 8 of 16
(6,759 Views)
Solved!! Thank you mcduff!
I installed the mxi-express-bios-compatibility-software and MAX is able to detect both chassis!
Message 9 of 16
(6,739 Views)
I'm having a similar problem where I recently purchased a PCI-8361 with a PXI-PCI8360 and installed it into a PXI-1036 chassis that was purchased in 2010.  I can't get NI MAX to recognize the 8360 -- instead it only permits the chassis to identify with an 8170 or 8150.  I've tried installing both PXI Platform Services 4.0.1 and 3.0.4 (after removing 4.0.1) in order to see if it would work with an older chassis version.  I've also tried MXI-Express BIOS Compatibility Software 1.5 & 1.4 (because that's the earliest version that is now available.)  I was reading that the BIOS Compatibility Software has compatibility with some 817X cards, so I tried identifying the cards as a 8170, which allows me to recognize the cards, but not operate the PXI-5122 Digitizer card in the 1036 chassis that I'm trying to use.  Please provide some guidance if you think you know the solution to this problem.
Message 10 of 16
(6,381 Views)
