NEw versionVI's on old labview?
Hi everyone!
Does anybody know, if (and how) it's possible to use VI's created on labview
6i in labview 5.1?
Thanx!
atsw
(2,876 Views)
Yes:
You choose file->save with options->save to previous version
James Annesley
"atsw" wrote in message
news:8vtlpd$5otbp$1@ID-48224.news.dfncis.de...
> Hi everyone!
labview
> 6i in labview 5.1?
> Thanx!
> atsw
(2,876 Views)
ATSW,
Older version Labview does not read any VI created on newer Labview.
"atsw" wrote:
>Hi everyone!>>Does anybody know, if (and how) it's possible to use VI's
created on labview>6i in labview 5.1?>Thanx!>>atsw>>>>
(2,876 Views)
In Labview 6, go to the file menu and select "Save with Options". In here is
an option "Save for previous" which allows you to save the VIs out in
Labview5 format. If the VI uses controls or trivial functions that are
present in LV6 but not LV5 they're converted, but more complex functions
aren't. For example, I saved out a VI from 6 today into version 5 format and
it failed to run because I was using some properties in the front panel
object that weren't present in LV5, breaking the property node.
Hugh Lu wrote in message
news:3a22c766@newsgroups.ni.com...
> ATSW,
le to use VI's
(2,876 Views)
