yes it's possible to start all 8 counter tasks without the "arm start" trigger. It's also possible to start 6 counters with the "arm start" trigger AND the remaining 2 counters without. Of course I get the "first sample is not valid"-problem on the counters started without the "arm start" trigger and I'd like to have all 8 counters running with only valid samples in their buffers.
The code I use to accomplish this is more or less the same as described here:
