NI 9205 Properties - EtherCAT vs DAQmx
If I have an NI 9205 module in an EtherCAT chassis, I can access a property called Minimum Conversion Time, by using a reference to the module:
HOWEVER
If I have an NI 9205 module in a cDAQ chassis, I don't see how to get a reference to the module.
If I try the usual way, by referencing the task, that property is not available:
Am I missing something?  or is it just not available under cDAQ?  I'm trying to use the same UI to configure a 9205 whether eCAT or cDAQ.
Steve Bird
Culverson.com
LinkedIn
(1,571 Views)
Seems like you are right. I tried to do some searching and looks like the "Conversion Time" is not under the Supported Properties. The list of supported properties is available Here
(1,491 Views)
Accepted by CoastalMaineBird
Looks like you are right. I tried to do some searching and there is no "conversion time" properties available under cDAQ. The list of available properties is available Here. Hope it helps.
(1,490 Views)
please ignore the first comment, I attached the wrong link
(1,484 Views)
