NI 9264 to produce 3 phase waveforms and shown in 1 chart
I tried using the sample Voltage Continuous Output and selected the channels 0, 3, and 6 to generate the same waveform but I encountered this error:
Please help.
Message 31 of 58
(1,116 Views)
The waveform settings array  - you need to add 2 additional elements in that array, one for each channel. I wonder if you can also setup the phase shift...
Message 32 of 58
(1,103 Views)
Thanks LVninja!
I will try it and let you know.
Message 33 of 58
(1,100 Views)
Thanks LVninja! you're the best!
Message 34 of 58
(1,090 Views)
Hi LVninja,
I set the phase for these 3 channels as 0 degrees.
I want to create the next two 3 phase waveforms with 120 deg and 240 deg phases.
Do I need to copy paste the whole program for 0 deg 2X or can I create an array in the Physical channels and just increase my array in the waveform settings?
Message 35 of 58
(1,087 Views)
You can create the 3 phases shifted (u need to add the phase input on the cluster) but there is a Boolean input (RESET) that needs to be true , otherwise all phases will be 0.
As for the DaqMX task, are you setting up the 9 channels at once ? if so then the Array needs to have 9 elements. Sorry I don't have the device, that part u need to figure out by yourself.
Message 36 of 58
(1,076 Views)
I already increase waveform array to have 9 channels used:
Message 37 of 58
(1,070 Views)
Message 38 of 58
(1,069 Views)
It looks like you created an array of 9 dimensions (🤷‍)
That should be 1 D array with 9 elements, one for each channel. Dont' forget to wire the Boolean TRUE on RESET.
Message 39 of 58
(1,064 Views)
 Thanks LVninja!
I will finalize and show it to you.
Message 40 of 58
(1,038 Views)
