NI 9269 minimum external resistance
I am trying to output voltage from NI 9269. According to
http://digital.ni.com/public.nsf/allkb/5FDA9006283BB603862578B5006A80E7
NI 9269 can take smaller resistance than 10 k ohms (that is the requirement for NI 9263) but the value is not reported.
What is the minimum external resistance required for voltage output from NI 9269?
Thank you,
(3,125 Views)
Accepted by tatsuya1
Hi tatsuya1
Very interesting question.
9269 outputs 10V @ 10 mA/ch. So  the minimum external resistance required is 1k ohm.
greetings
Erwin Franz
Certified LabVIEW Architect, Certified TestStand Developer
(3,116 Views)
Thank you Erwin!
(3,060 Views)
