NI 9481
I am trying to use a NI 9481 relay module to turn a light on and off.  How can this be done using Daq Assistant?  I simply want to program a boolean switch to open and close the circuit.
Thanks!
(1,493 Views)
Accepted by NickIke1
Hi Nick,
Start with NI-MAX!
It provides testpanels - and you can easily test your NI9481 to switch a relay.
Afterwards you can create a DAQmx task from your settings and use that task in your VI. I recommend to learn basic DAQmx functions instead of relying on that (dreaded) DAQAssistent ExpressVI!
(1,456 Views)
