03-21-2022 03:52 PM
I am trying to use a NI 9481 relay module to turn a light on and off. How can this be done using Daq Assistant? I simply want to program a boolean switch to open and close the circuit.
Thanks!
Solved! Go to Solution.
03-22-2022
03:27 AM
- last edited on
07-16-2026
11:12 AM
by
Content Cleaner
Hi Nick,
Start with NI-MAX!
It provides testpanels - and you can easily test your NI9481 to switch a relay.
Afterwards you can create a DAQmx task from your settings and use that task in your VI. I recommend to learn basic DAQmx functions instead of relying on that (dreaded) DAQAssistent ExpressVI!
