NI 9881 module, MAX can't find the CANopen port.
Do I have to use FPGA? I'd prefer using the Real-Time system.
There is power at Pin 9, I measured it multiple times with a multimeter. It's 23.7 V so that should be alright.
I found the tab in MAX, where I got the CANopen Interface, so thats correct in the the Interface Create VI. And even with the 23.7 V there's an error saying the transceiver got no supply voltage.
Message 21 of 23
(840 Views)
Hey guys,
I have the same problem using a 9045 controller and the 9881 module for CanOpen communication. I'm using a windows 10 system with LabView 2018 32bit, Real-time 2018, NI-cRIO 18 and the NI-Industrial Communication 18.0. The newest version of the Communication driver which is available online is 20.0. The power supply (24 VDC) is connected to Pin 9 and 6 of the 9881 module. The two LED of the module are off. I bought the whole system 6 month ago.
I can see the module in MAX. But not in the right way I think. See Picture 1.
I tried to run an example vi like "CANopen Read Write CAN Frame.vi" (Picture 2).I just opened th vi not the porject data. I changed the baudrate to 250 kbit/s due to the fact that my other CanOpen devices are running at this baudrate. Do I have to change the node ID?
Running the vi I got the error message picture in picture 3. The device cRIO 9116 cant't be found. Off course - I'm using a cRIO 9045. Where can I change this setting?
I opened the project folder as well. See picture 4. How can I replace the default device 9116 with my cRIO 6045.
Can someone support me and the other people to run the CanOpen module?
Message 22 of 23
(815 Views)
Hi Stefan,
Did you read the comment on the top of the front panel? There it says: "change the NodeID to the slave ID"…
When you want to communicate with a slave (aka your other device) then you need to supply its CANopen ID!
The example is made for a "rather generic" target. You need to replace the target to your own cRIO.
(Or you duplicate the code to your own project.)
Message 23 of 23
(812 Views)
