Showing results forĀ
Search instead forĀ
Did you mean:Ā
NI CB-68LP
i have NI CB-68LP  data acquisition device , i want to know if labVIEW signal express work with it
(2,672 Views)
Hi Mahmoud,
This is not a DAQ device, this is a plain connector block…
Which device is this connector block connected to?
(2,662 Views)
It is  pci 6024E
(2,618 Views)
Accepted by topic author MahmoudSaad
Hi Mahmoud,
when DAQmx supports this old PCI DAQ card then SignalExpress will also support it…
(Read the help on DAQmx to learn about supported devices.)
(2,614 Views)
