10-07-2025 05:18 AM - edited 10-07-2025 05:21 AM
Hi! I have been trying to download LabView for a university project. I managed to download just LabView with every extra unticked, and now trying to download individual packages. I downloaded NI-Serial with no issues - again with every extra unticked.
Packages think I need:
NI-DAQmx - use with NI USB-6001
NI-IMAQ - camera
NI-IMAQdx - USB webcam
NI-VISA - use with TCP board
My processor:
64-bit operating system, ARM-based processor, Snapdragon(R) X Plus - X1P42100 - Qualcomm(R) Oryon(TM) CPU (3.24 GHz)
I received this same error for all of the packages. The project is pretty flexible so I am open to suggestions on workarounds or other recommendations.
Thank you for reading, any help hugely appreciated.
The error message:
10-07-2025 05:55 AM - edited 10-07-2025 05:56 AM
Hi Bob,
@spongebob6 wrote:
My processor: ARM-based processor, Snapdragon(R) X Plus - X1P42100
Recommendation: use a different computer with a x64 CPU (Intel, AMD)…
The error message in the image is quite clear on that issue!
10-07-2025 06:13 AM
Hi GerdW, I understand, however, this is the PC that is available to me!
10-07-2025 06:35 AM - edited 10-07-2025 06:35 AM
Hi Bob,
Then you (or someone else) missed to check the requirements for the project before you (or someone else) decided on the hardware/software to be used.
In your case: the laptop does not fit to the project requirements!
When you need LabVIEW with (lots of NI) hardware support than you should use a computer with a x64 CPU…
10-07-2025 09:54 AM - edited 10-07-2025 09:59 AM
It's even more limited than just the CPU. NI DAQ hardware, do not support any of the USB based DAQ hardware on any system but Windows. That includes your USB-6008. And no, Windows RT or any of the newer Windows for ARM are not a solution, it has to be Windows on an x64 CPU.
