NI-DAQmx 8.9 and 9.0.2 simultaneous install?
I have 2009 and 7.1 on the same machine.  When I install DAQmx 9.0.2 for 2009, all my acquisition vi's for 7.1 (installed with NI-DAQmx 8.9) go missing.  Is there a way for 7.1, 2009, and DAQmx 8.9 and 9.0.2 all to co-exist on a machine?  Currently, I am having to uninstall and install the acquisition drivers each time I switch LV versions.
Greg
v7.1
Message 1 of 9
(4,062 Views)
You can only install one version of DAQmx. You can, however, install multiple versions of LabVIEW. Unfortunately, there is no DAQmx version that supports both 7.1 and 2009.
Message 2 of 9
(4,049 Views)
Accepted by gstanczak
Hi, there is a thing to do before installing DAQmx, save repertory of LV7 and after install ofDAQmx copy the save and all working well. (only express will not work).
Regards
Greg S.
CNRS
LV 7.1 8.2 8.6 2009 2011 2012 2013 2014
LPMC - CNRS
N'oubliez pas de complimenter cela fait toujours plaisir.
Message 3 of 9
(4,043 Views)
Greg,
I am very anxious to try this.  I will report back to confirm it works.
Greg
v7.1
Message 4 of 9
(4,037 Views)
I doubt this will work. While the VIs may be there, the underlying DLLs that get called are different. At the very least the code will likely not even run.
Installing NI-DAQmx Support for LabVIEW 2009 & Labview 8.0 or Prior
Message 5 of 9
(4,029 Views)
Rats.  But, I have do find that an executable made with 7.1 seems to work with DAQmx 9.0.2.  Maybe this makes perfect sense?  I don't know.  Can I rely on this?
Thanks for the advice,
Greg
v7.1
Message 6 of 9
(4,022 Views)
for me it is working, still have LV7.1 8.2 8.6 and 2009 on same computer no problem with old VI before DAQmx 9.0.2 to work with. It was same when update to LV8.6 there was no support DAQmx for LV7.1 and NI support said to me to do like this.
Greg S.
CNRS
LPMC - CNRS
Message 7 of 9
(4,001 Views)
I will still no doubt give your suggestion a shot.  Didn't have a chance yesterday.  Hopefully today.  For this project I am only concern with basic I/O functions.  One of smercurio's post makes me wonder if certain acquisition vi's will work (if new and old .dlls are the same or similar) while others will not (if new and old .dlls are significantly different).
Cheers,
Greg
v7.1
Message 8 of 9
(3,984 Views)
I can only speak for a handful of the basic IO vis, but your idea to copy the 7.1 folder, install DAQmx 9.02, then copy back the 7.1 folder, is so far working.
Thanks!
Greg
v7.1
Message 9 of 9
(3,770 Views)
