NI IMAQ
你好,我正在安装labview 19版本。我已经安装了所有用于视觉图像采集的软件,例如NI IMAQ和视觉采集软件。但是,我在Vision and Motion中找不到Machine Vision,因此找不到图像处理控件。我不知道发生了什么?我已经激活了 NI IMAQ。
谢谢。
(1,461 Views)
Vision Acquisition Software is what you already have installed.
What you need to install is Vision Development.
Vision Development Module-Download - NI
CLA
(1,446 Views)
@LIFangfang  wrote:
Hello, I am installing labview version 19. I have installed all software for visual image acquisition such as NI IMAQ and visual acquisition software. However, I can't find Machine Vision in Vision and Motion, so I can't find the image processing controls. I don't know what happened? I have activated NI IMAQ.
Thanks.
Check whether you are able to see the VISION Installation in the NI MAX Software list, Something like the below image.
(1,368 Views)
Thank you so much. I have successfully solved the problem. Please accept my sincerest blessings for your help.😄
(1,341 Views)
