NI Update Service Error
I am having problem with installing updates using the Update Service. I was able to download all the updates, but I am having trouble installing them. I got the following error. error.png
The Update Service version is 2.3.0.70. I tried to run it as administrator and disable the firewall, none worked.
(5,391 Views)
This happened to me yesterday at home partway through a download, I clicked Try again and it picked up where it left off and finished the update installation without issue.
-AK2DM
(5,373 Views)
Accepted by rhong
when you try again does it still give you a problem?
which update(s) are you trying to install?
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
(5,365 Views)
Hi Jeff,
The updates are working now. I think because I have a lot of updating to do, some of the patches might be incompatiable with others. Instead of downloading all of them at the same time, I'm updating a few at a time.
(5,345 Views)
