NI cDAQ - select signals
I have a simple VI here to read selected input values from a 9221 module on a cDAQ. The output values are formatted as a string. I'd like to output a second string that contains the names of the inputs I have selected so that I may write it to a file in a format looking like this:
#0, #3, #4, #7                    <--- this is the new string
10, 12, 11, 18                    <--- the string I already have
The top line shows the names of the selected inputs, and the bottom contains the measured values.
Thanks!
Message 1 of 9
(3,435 Views)
Do you only want to put the label on the first line and then just log data after that or do you want lables every time? Where are you going to get your lables from? Are you  going to use names from a control, user imput names, chanel names etc...?
Tim
GHSP
Message 2 of 9
(3,430 Views)
Yes, label only on the first line. I was thinking two separate strings(one for labels, one in a loop for data to keep being recorded)
Labels that I name would be best (just something like "input1", "input2", etc.). But this isnt too important as long as it's clear which channels the names correspond with.
Message 3 of 9
(3,425 Views)
Are you going to be taking data continuously or one time shot?
Tim
GHSP
Message 4 of 9
(3,420 Views)
once at a time
Message 5 of 9
(3,414 Views)
Like this
Tim
GHSP
Message 6 of 9
(3,405 Views)
I appreciate the help but this isn't quite what I'm looking for.. I need it to only show the labels of the items I have selected, not all of them. That's where I'm having problems. Thanks
Message 7 of 9
(3,398 Views)
Accepted by ENGRLAB
It seems like you could create your own search function to look through the array of booleans and produce numbers that correspond to them.
See my attached code.  I leveraged the power of the for loop, auto-indexing, and shift registers to complete this.  I think it pretty closely matches your needs, although you may need to tweak it slightly.  Also, you will have to change your DAQ channels in the assistant, as I changed it to something on my system to try the VI out.
Paul Davidson
Product Owner - ni.com Chat
Message 8 of 9
(3,369 Views)
This is perfect! Thank you very much
Message 9 of 9
(3,360 Views)
