Need Help Implementing Ramp Function for Kikusui Electronic Load PLZ205W in LabVIEW
Hi GerdW,
When I give all the needed data as array, the loop is finishing all the iterations and only it is passing the array with last ramp values.
Message 21 of 30
(2,147 Views)
Right click on that tunnel inside the red rectangle and choose Tunnel Mode->Indexing. Et voilà!
Rolf Kalbermatter  My Blog
Message 22 of 30
(2,136 Views)
Hi Varghese,
@Varghese89 wrote:
the loop is finishing all the iterations and only it is passing the array with lastvalues.
To put it in other words than Rolf: this is because YOU set the output tunnel to "last value" mode!
  • I recommend the "concatenating" mode instead of "indexing" as you want to concatenate all the ramps.
  • Why do you subtract a constant 0 from all values of the upper input array?
  • Why do you subtract the lower array inputs from constant 0?
  • Why don't you cleanup your block diagram?
Message 23 of 30
(2,132 Views)
FYI, if anyone posts code snippets that look like below, you can drag and drop them onto your block diagram, see this article about using code snipits:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
Drag this image onto your block diagram:
If dragging and dropping does not work download the image and drag the PNG onto the block diagram.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 24 of 30
(2,118 Views)
Hi Jay,
Thank you for your help. This is working for both ramp up and ramp down. I also need constant ramp with zero ramp rate.
Message 25 of 30
(2,101 Views)
Hi GerdW,
I sincerely thank you for your valuable help. concatenating served the purpose. I have also cleaned up the block diagram.
Message 26 of 30
(2,095 Views)
Hi Varghese,
A "constant" ramp uses a step width of 0 (aka "zero ramp rate").
Hint: You can define a ramp also by start, end and number of steps…
Message 27 of 30
(2,079 Views)
Hi GerdW,
Thank you for the hint. For a constant ramp, the start and stop values will be same and Yes, I was to specify the array size for which the value is constant. Currently I am checking the number of iterations based on the Quotient obtained from subtracting the difference of start and stop value with ramp rate plus 1. I am confused how to implement the constant ramp. I understand i need to check if the difference is zero and to input the number of iterations, but I am confused how to implement it, can you please elaborate.
Message 28 of 30
(2,073 Views)
Accepted by topic author Varghese89
Hi Varghese,
Simple approach:
IF step_width == 0 THEN
  RAMP(start, end, number of samples)
ELSE
  RAMP(start, end, step_width)
ENDIF
A simple case structure and two different ways to create the ramp will solve the problem!
(You can reduce the problem to two ways to create the ramp parameters, then you call a generic Ramp(start, end, number of samples, step_width) function.)
"Programming" means to develop algorithms (independently from the language you use).
Often it helps to "divide and conquer"…
Message 29 of 30
(2,057 Views)
Thank you so much :'). Case structure solved the problem.
Best Regards,
Varghese
Message 30 of 30
(2,048 Views)
