Need Help regarding Time control in labview
hello eveybody,
In the attached image there is a vi that i made to control the amplifier.
I give amplitude DBL value to the Amplifier like 50V or 60V and it is there on amplifier.
They problem is that I need to control the amplitude with the timing. Like i want 50V continious for 5 sec and then a sudden peak of 100V for like 1sec or 1msec and so on.
What should i do?
Any help...!!!!!!
Message 1 of 11
(4,637 Views)
Something like this could work.
The two Array contain your wished cycle data.
Voltage
050V
1100V
2xx V
etc.
Time
05000 ms
11000 ms
2xx ms
etc.
So you can build your cycle.
It's not a sophisticated solution but easy and quick.
regards,
adigator
Message 2 of 11
(4,610 Views)
Sermand, are you running a Real-Time System?
Christian
Message 3 of 11
(4,604 Views)
Yup it is a real time system....!!!
Message 4 of 11
(4,579 Views)
adigator
Thank you for your replay.
Can you please attach the image of the vi so that i can viewit ?
The thing is I donot have a labview at my home pc!
Message 5 of 11
(4,573 Views)
Message 6 of 11
(4,537 Views)
Accepted by Sarmad_101
Thanks adigator
I find out the solution and now I got what I was thinking...
Message 7 of 11
(4,514 Views)
Interesting Solution
Message 8 of 11
(4,490 Views)
Message 9 of 11
(4,473 Views)
I really think you should go with adigator's solution.  You can just pass in the arrays and call it a day.  It's a lot simpler to figure out as well.
Message 10 of 11
(4,462 Views)
