Need Help with DAQ in Labview
Hi Dennis,
I tried to append the waveform like you had suggested with a for loop and I also initialized the shift register with a empty waveform but I end with the same thing because the empty waveform is not updating its value...which i don't know why.....kindly look into my VI and let me know the possible reason for it and how can I overcome this problem...
Thanks and regards,
Suresh
Message 11 of 15
(1,446 Views)
Accepted by Patra79
No, the shift register is in the wrong place.
Message 12 of 15
(1,444 Views)
Hi dennis,
I just ran the modified VI which gave but the for loop is not executing and returning the value 0 but rest of the program runs fine.
Thanks and regards,
Suresh
Message 13 of 15
(1,438 Views)
Sorry, the inner for loop is not executing because of the initally empty array. It's auto-indexing and a for loop will iterate to a count equal to the size of the smallest array. You could change it to not auto-index and wire a count to the N terminal since you know how many channels you are capturing. A couple of index array functions inside could be used.
Message 14 of 15
(1,434 Views)
Hi Dennis,
Thank you very much....its doing what I wanted...thanks again!!!!!
Suresh
Message 15 of 15
(1,430 Views)
