Need advice on setting Call Library Function Parameters
Hi All.
I am trying to configure a call library function with the following parameters from MSDN
BOOL WINAPI GetConsoleScreenBufferInfo(
  _In_  HANDLE                      hConsoleOutput,
  _Out_ PCONSOLE_SCREEN_BUFFER_INFO lpConsoleScreenBufferInfo
For the types HANDLE and PCONSOLE_SCREEN_BUFFER_INFO what should they be set to. These are C++ parameters and there is no documentation of how to use them in Labview. Does anyone know how to set them up??
Thanks.
Message 1 of 17
(5,859 Views)
Hello
Usually for handle type you need to use i32 and for Screen_buffer_info I would guess string. Try it and let me know whether it works 🙂
Marcin
Think Dataflow - blog.mtapp.tech
Message 2 of 17
(5,840 Views)
No that hasn't worked. When I create both the input and the output it creates an in and an out for each. Should there be just one input and one output?
Message 3 of 17
(5,835 Views)
I'm not sure but I think it's expected behaviour because the function just needs the refernece for the out parameter. Do you have some error right now or just the behaviour is different than expected?
Message 4 of 17
(5,833 Views)
The error code is 1517. Call Library Function Node
Message 5 of 17
(5,828 Views)
Can you send some code of your application?
Message 6 of 17
(5,818 Views)
The vi is attached. i run a cmd window in the background and then run the vi hoping to get the data from the cmd window.
Message 7 of 17
(5,814 Views)
Sorry I missed the VI.
You cannot pass 0 to the handle because it doesn't mean anything. You have to know the handle to the console and I am not sure how to get the handle to the already open cmd window.
Can you maybe call the cmd window directly from LabVIEW? Then I suppose getting handle to it would be easy.
Message 8 of 17
(5,807 Views)
In this vi I have called the command window and implement a keypress. is it possible to get the handle from this?
Message 9 of 17
(5,802 Views)
Try to use this function:
https://msdn.microsoft.com/en-us/library/windows/desktop/ms683231(v=vs.85).aspx
You want to get handle STD_OUTPUT_HANDLE.
Message 10 of 17
(5,799 Views)
