Need handheld voltage probe with data entry (similar to bar code scanner)
Hello all, first post here and newish user of LabView.  I am creating a VI to measure legacy equipment that has test points unaccessible with a connector or bed of nails.  Does anyone know of a handheld voltmeter probe that can be used to probe a test point, then have a pushbutton on the probe to enter the value measured as text?  I have not been able to find such a gadget.  The idea came from handheld bar code scanners that have a button to make the scan, and will then enter the scanned value as text into a spreadsheet.  Thanks for all responses.
(1,124 Views)
I haven't seen anything like that.
But there are multimeters available with communication ports that can be used to get measurements from the instrument. Then you can attach a probe clip to a test point and press a button on the screen to retrieve that measurement.
=== Engineer Ambiguously ===
(1,111 Views)
Accepted by MKBNIS
I unfortunately don't know of a turn-key solution, but like RTSLVU said lots of voltmeters have communication options with cables. I have a Fluke one with Bluetooth as well, though I've never tried to interface it with anything except the official phone app.
You could set up a foot switch to take the reading, or just hit the spacebar to capture a measurement. Or a combo of a voltmeter with communications and a wireless slideshow clicker.
If you're handy with a 3D printer, I think I'd try making a housing that holds a slideshow clicker thing and a voltmeter probe, or perhaps a small Arduino clone that reads a handful of buttons in a custom housing that holds the meter probe and sends that to the computer to say "take a reading".
(1,089 Views)
In these situations, I typically just trust the technician to take the measurement manually and input it into my software.
(1,076 Views)
Thanks for the replies everyone, after talking to our manufacturing engineer he said that it would be better to use a footswitch, as manipulating a switch on the probe itself might cause slipping off a pin and causing a short.  There are quite a few suggestions on how to implement a footswitch, so I'll go in that direction.  Thanks!
(1,037 Views)
