Need help with an array
Well guys I have an array that gives me positive and negative values.
I need to use this array and get 2 new arrays, one is the array of positive values, second is the array with negative values, after that i have to get 2 values from it, one is the sum of all positive elements and i need to know how much positive elements too.
the second value is the sum of all negative elements and how much negative elements too.
Example:
Array: 5, -12, 2, -3, 4
First Array: 5,2,4
First Value: 5+2+4 = 11
Numbers of elements: 3
Second Array: -12,-3
Second Value: -12+(-3) = -15
Numbers of elements: 2
Something like that!
Message 1 of 20
(6,244 Views)
Something like this maybe, assuming zero is positive.
Dan
CLD
Message 2 of 20
(6,234 Views)
Hey Dan thanks for the example, it works for me but I need get 2 arrays too
one with all positive values, and the other with all negative values!?
it can be made?
Message 3 of 20
(6,226 Views)
The attached code will work for your requirement..let me know if you have any problem with this..
Message 4 of 20
(6,224 Views)
EduU,
There are plenty of ways to do this, here is just one:
Rgs,
Lucither.
"Everything should be made as simple as possible but no simpler"
Message 5 of 20
(6,213 Views)
G.K and Lucither could you guys make it to 8.6 LabVIEW version?
I can't use the option to take the image and put into labview.
But thanks for the help guys
This probably will solve my problem!
Message 6 of 20
(6,208 Views)
No worries,
Here it is in 8.6
Rgs,
Lucither.
Message 7 of 20
(6,205 Views)
if you want the ending array add a biuld array to both the cases like this:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 8 of 20
(6,204 Views)
Accepted by EduU
here is my 8.6 version
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 20
(6,201 Views)
Thanks for all the solution!
I used the Harold Timmis as my solution
But all others give me a really nice feedback!
Message 10 of 20
(6,177 Views)
