Need help with buffering issue
The name isn't all that important.  I was more curious as to what roles you were reaching out to.
Did you have any luck with the Configure Buffer VI?
Message 11 of 14
(750 Views)
With the Configure Buffer VI, what exactly are you referring to? In the VI, configure buffer.flx is used before "Check Buffer". Whenever I search for "Configure Buffer", only the .flx, or the Daqmx VIs pop up.
Message 12 of 14
(741 Views)
I actually figured out this problem. The maker of the VI included a buffer in the portion that doesn't require any motor movement, so I removed everything from that specirfic sequence and rewired and it worked!
Message 13 of 14
(718 Views)
That sounds like a much easier fix than any of us were looking for.  I'm glad you figured it out.
Message 14 of 14
(699 Views)
