Nested If and else without case structure
Hello All,
Lets talk about this.
In my project I dont want to use Case Structre/Stacked str for Nested If else conditions.
I think we can use Selector for this. Yes I know it's quite complicated solution but i want to these kind of alogrethims (PFA).
could you please tell me how much possibility (%) is there in LabVIEW without using case structure to implement any kind of logics.
Thanks & Regards,
Guru
Munna
Message 1 of 45
(5,857 Views)
Hi Guru,
could you please downconvert your VI to LV2011?
Why don't you want to use Case structures at all? Is this some kind of arbitrary limitation?
Message 2 of 45
(5,841 Views)
Dear GerdW,
Thank you so mcuh for your reply.
As per my cleint request I can't use Case structre so I'm searching for better solution to solve my problems.
Please help me.
Thanks & Regards,
Munna
Munna
Message 3 of 45
(5,825 Views)
http://notalwaysright.com/
You've been hired as the expert.  Take a shot at convincing them that avoiding Case structures is silly.
Perhaps they're using an older version of LabVIEW with a license that doesn't include Event structures and they've mistakenly proscribed Case structures?
Jim
Message 4 of 45
(5,820 Views)
Dear Jim,
We are using LabVIEW 2012.  Sometime I used Case Str and Event structures.
Now I'm trying to Avoid these. I want to know what is the problem if I'm using Selecor instead of Case Structure in all the cases.
BR,
Munna.
Munna
Message 5 of 45
(5,811 Views)
Hi Munna,
there is no "problem" to use Select function in favor of Case structure.
It just produces bigger block diagrams, produces (sometimes) harder to read (and maintain) code, - and it's just silly to not use an elementary programming structure offered by the IDE…
Message 6 of 45
(5,807 Views)
Dear GerdW,
Thank you so much for your support as always.
Yes, you're right. it's quite difficult to maintain the code if no. of cases are more.
I think we can use Selector instead of case structure for all the cases.
I mean,  case-1 Read the Text file case-2  Read and write to text file case-3 some String operations etc.
BR,
Munna
Munna
Message 7 of 45
(5,802 Views)
Hi Munna,
the difference between a (proper) Case structure and your "Select" approach is:
in a Case structure only the code in the selected case is executed. When using Select instead all the time all code has to be executed (THINK DATAFLOW)!
So decide on your own if you want to refuse from using Case structure…
Message 8 of 45
(5,797 Views)
Think of a statemachine running without case structure...... *shudder*
Norbert
Norbert
Expert: Geometry
Message 9 of 45
(5,789 Views)
Dear GerdW,
You're correct.
I think execution time also will get increase with Selector approach (If cases are more).
Now, we are not thinking about how many cases executed/ time. Just I want to know how much possibility is there if I'm using Selector to implement any kind of Logics.
BR,
Munna.
Munna
Message 10 of 45
(5,786 Views)
