Nested If and else without case structure
Dear Norbert,
Give me some sample example.
I think we can use Statemachine without case structure. what you think?
http://www.ni.com/white-paper/7595/en/
BR,
Guru
Munna
Message 11 of 45
(2,550 Views)
Hi Munna,
a state machine is essentially a Case structure inside a While loop.
How do you want that to run without the case structure???
Message 12 of 45
(2,548 Views)
Dear GerdW,
I think we can create statemachine also without case str. Please correct me if my undestanding is wrong.
BR,
Guru
Munna
Message 13 of 45
(2,535 Views)
Hi Munna,
a state machine is more than just to decide what state to execute next!
As said before: in a case structure only the code in the current case is executed - in your (silly) approach all code is executed…
Message 14 of 45
(2,528 Views)
@Munna232 wrote:
[...]Please correct me if my undestanding is wrong.
BR,
Guru
Guru,
please stand corrected.
You are mistaken with your assumption, that case structure only "selects between return value options". Gerd already pointed out that you select for functions you execute or skip.
Your code has no chance of skipping code execution, so it will always execute all code. This will waste performance in the best case, in the worst case it will kill your whole computer, maybe even damaging peripherals.
Excluding specific pieces of code dynamically is an essential part of every programming language. Without that option, most of todays applications would not exist.
There is, on the other hand, a technique of implementing state machines without case structures:
Dynamic calling VIs using VI server.
This approach, however, is heavily convoluted, wastes performance at a great deal and is way more complex than case structures.
Norbert
Norbert
Expert: Geometry
Message 15 of 45
(2,524 Views)
Dear Norbert,
Thank you so much for your valuable Information.
Yes, I will agree with you're point,
Just I'm trying to get the information how much possibilities are  there with LabVIEW for these kind of approaches.
For you're information, In simulink we are not using Switch case. Instead of this we are using Multiport Switch (like Se
lector). We never faced any issues.
http://www.itu.dk/stud/speciale/segmentering/Matlab6p5/help/toolbox/simulink/slref/multiportswitch.h...
BR,
Guru
Munna
Message 16 of 45
(2,519 Views)
Hi Munnam
how is Simulink coding related to writing LabVIEW VIs?
Message 17 of 45
(2,517 Views)
Guru,
Although it is possible to code using any imaginable approach, does not make it the "right way".  There is more to writing software than "making it work".  Heck, anyone, given enough time can write something that will execute.  Just as 1000 monkeys hitting a keyboard will write meaningful words...  But do the words or (if you can call them ) sentences make any sense?  Do they convey what the monkeys are thinking?  I doubt it.
Writing software needs to be done in a manner that when yourself or someone else reads that code in the future, or needs to scale or maintain the code, that it is possible to do so.
Often, when dealing with badly written code, it takes more time to decypher the actual intent, or to modify code which is not scalable; than to write the code from scratch.
Message 18 of 45
(2,512 Views)
Please explain the reason behind the decision to avoid Case structures.
Jim
Message 19 of 45
(2,508 Views)
Dear GerdW,
I don't know relation b/w Simulink and LabVIEW VIs.Infact I don't know how they implemented simulink blocks in MATLAB.
Just we are using Slector kind of SW in Simulink block instead of Switch cases.
BR,
Guru
Munna
Message 20 of 45
(2,505 Views)
