New Vi Object - Replace Array Subset, resize and wires Script
Hi all,
I can create a Replace Array Subset.
my problem is:
I what to resize it (add more inputs ) and wire the in and outputs.
Pls help!
i want to generate semthing like this:
(4,006 Views)
There are many array functions to choose from.
You haven't really given us much information because you say "i want to generate semthing like this:". If that's what you want, there you go.
If you want to replace array subset, but also resize, you can use the Insert Into Array as well.
Cheers
(3,983 Views)
Accepted by mogergog
There are two methods of the GrowableFunction class, AddChunk and RemoveChunk, which can be used to add or remove X input chunks from the top or bottom of the node.
(3,950 Views)
