07-19-2017 05:59 AM
I am sorry if I will come off as ignorant or just plain dumb because of this easy problem. I just started using Labview last week and I don't get the grasp of it yet. I started with simple applications and I wanted to build a temperature converter from K to C and F, and F to C and K, C to K and F, but I cannot seem to find a way to connect two wires to one thermometer (by doing two different arithmetical operations), maybe I need to go deep down into programming, but I am not sure. If any of you could help me and give me a little push so I can get this done, I'd be very grateful to you.
I made the basic conversion from F to C from one of the NI tutorials.
Hope my explanation wasn't too difficult to understand. Also, I am using LabView 2015.
Thank you a lot in advance and have a nice day!
Solved! Go to Solution.
07-19-2017 06:16 AM
So you want two sources to go into a single indicator? That you cannot do. Only one node can be a source on a wire. So the better question would be why do you need multiple sources? Which source should be displayed when? It could be a simple adding of a Select? function with a button or an enum controlling a case structure whose output is wired to the indicator.
And since you are new...
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
07-19-2017 06:17 AM - edited 07-19-2017 06:18 AM
Hi yet,
which "thermometer" do you want to use twice?
General rule: LabVIEW follows the main mantra of THINK DATAFLOW!. Each data sink (=indicator/local variable) can only have one data source (wire!) connected.
Additional suggestions:
- For each thermometer control/indicator you can show a "digital display" with just a right-click. This way you can reduce your block diagram size quite a lot.
- Using AutoCleanup (Ctrl-U) from time to time would be nice too!
- Placing related controls and indicators on the frontpanel next to each other helps to understand your VI too…
07-25-2017 02:44 AM
Thank you a lot for taking time and replying to my problem. And sorry for the late reply. I just wanted to see if I could do the conversion two way for each of the measurement units, it is not a mandatory thing, so I won't be digging into it too much ... it was just a fun task I tried to do, but I will not go further into it.
Also, lots of thanks for the links, will access each one of them!
07-25-2017 02:47 AM
Hi there, thank you for replying to my post.
I wanted to use each of the thermometers two times, but I see that it is not possible, so I won't be getting too into it because I just wanted to try some things and see how they work in labview, but this is not the field I need to learn how to work with labview.
Also, lots of thanks for your suggestions!
07-25-2017
10:21 AM
- last edited on
06-01-2025
05:08 PM
by
Content Cleaner
You need to read about and learn to use the case structure and Enumerated Type.Def. (Enum)
For this program I would envision an Enum to select the "input units" and another one to select the "output units".
Then use these two selections to drive a case that selects the proper formula to make the conversion.
