Newport XPS Motion Controller
The vi is attached here.
Message 11 of 20
(2,849 Views)
I donot get any error. The stage just does not move at all.
Message 12 of 20
(2,849 Views)
What should be the Group Name for a particular stage.
Message 13 of 20
(2,848 Views)
Try this snippet to verify that the Comms is working.  Don't forget to change the IP address to match your system.
Message 14 of 20
(2,839 Views)
Hey Ken,
Can you please provide the vi for the snapshot.
Message 15 of 20
(2,835 Views)
VI Attached (LabVIEW 2016)
Message 16 of 20
(2,831 Views)
Dear Ken,
Thanks for the vi. It is communicating with the motion controller but I am not able to move the stage with my code.
Message 17 of 20
(2,828 Views)
These are the errors which I am getting.
Message 18 of 20
(2,825 Views)
I don't think you need to login unless you enabled some security features. To configure your group and positioner names, go to the web interface. My "Front Panel" looks like this. I have groups: Group1, Group2 each with one positioner, which are named Group1.Pos and Group2.Pos respectively.
Also, when sharing error information, it is helpful to share all the error information from LabVIEW, including the code (numeric) and source (string).
Message 19 of 20
(2,819 Views)
Error -18 is "Positioner name doesn't exist".  So you are connecting, it's just not able to move because the positioner name you gave it is wrong.
It's almost certainly the fact that you need to use "Group1.Pos" instead of "Group1" as the input.
The other error, -123, is due to the fact that only one connection can use the administration login at once.  As mentioned, for 99% of functions you don't need to be an administrator, so just get rid of the login VIs.
Message 20 of 20
(2,814 Views)
