No arrow on front panel or Block dia. Why?
Using 6.1
Message 1 of 9
(3,687 Views)
Your question is a bit ambiguous, but let me guess:
You don't see the "Run" button.
--> Go to "VI properties..Window appearance..Customize" and put the checkmark back in the "show run button" entry. (Or simply change it back to "default" on the main "window appearance" screen).
(Decorative arrows are in the decorations palette for the front panel. In you want one on the diagram, just cut&paste one from the FP.)
Message 2 of 9
(3,687 Views)
I believe setting a VI as "sub-routine" will have the same effect.
That's my guess.
Ben
Message 3 of 9
(3,687 Views)
Thank You For your help
I am Stilling new at labview
Message 4 of 9
(3,687 Views)
Hi Ben
I took a basic class with Tom Back in May
I was in your class on the overview of the project
I can sure use some help on my project that i am on
Please e-mail me thanks
Frank
e-mail fgott@americanndtinc.com
Message 5 of 9
(3,687 Views)
Hi Fgott,
There were a lot of people in that seminar.
I try to keep efforts that start on this Exchange public. This serves the broader community and allows me to help more than just one person.
I will have Tom give you a call in the event you want to talk off-line.
Otherwise,
Just start asking away! Try to post seperate questions for each topic. This will give you maximum exposure to the collection of minds gathered here.
Trying to help,
Ben
Message 6 of 9
(3,687 Views)
Just for the record;
What did find out about the run arrow?
Ben
Message 7 of 9
(3,687 Views)
It was turn off under the VI prop. But evertime I start the VI it is turn off. Then I have to go into the VI Prop. to turn it on again. Do you know Why.
Message 8 of 9
(3,687 Views)
Please post the VI for us to look at.
THat will make this much easier to chase down.
Ben
Message 9 of 9
(3,687 Views)
