First, thank you for your answer.
In fact I had an older verison of the vi (developped with LV7.1). I tried to compile this one (still with LV7.1) and to install it on the second computer (I am the administrator of this machine) after unistalling the version that did not work. This older version worked perfectly.
Then I tried to install again the new vesion (installer compiled with LV8.2.1 and its app builder and with Vision LV8.2). Again this version does not work on the second computer (no image). And the older version does not work anymore (no image).
Then I developped a little vi with LV8.2.1 (this vi only acquire images and displays them), then I compiled it into an executable and I tried it on the computer. This one works perfectly, the iages from the camera are correctly displayed.
I think there is something wrong with the installer but I can't figure out what could cause such a problem.
How can I try in debug mode with a compiled version ?
Regards
