Noise tracking
Hi, I am trying an application of Noise Tracker. I am using the PXI DSA board (4472) to track the sound and I am using 7 microphones. I am planning to integrate this array with a camera, (probably a fire wire camera with CVS). I need some help on noise mapping. Does anyone have an application of the same?
Also, does the number of microphones matter for the application. If I reduce, would I get a better noise tracking application?
If someone has done a similar application, please guide me how to go about it. If you have any piece of related LabVIEW code, kindly share the same.
Guru
(3,527 Views)
Has anyone worked on a similar application?
Guru
(3,437 Views)
Are you lookin for something like http://zone.ni.com/devzone/cda/tut/p/id/6267
(3,417 Views)
I'am also doing this. That would be very nice if anyone can share a basic code
Thank a lot!
Nghia
(3,128 Views)
