Non Linear Curve Fitting - BET Calculation
Hello, I am new to the LabVIEW community.
I am trying to do BET Fitting in LabVIEW.
Until now it was done in Excel using the Solver add, but I want to include this Fit-Model (and several others GAB,...) in my LabVIEW program. I am using the Nonlinear Curve Fit.vi but I am getting different results than with the Excel Solver add.
Any Help would be much appreciated.
I attached my Vi and the Excel File.
(1,831 Views)
You use a formula
m*c*a/((1-a)*(a+(c-1)*a))
While it should be
m*c*a/((1-a)*(1+(c-1)*a))
See if that helps.
(Also note that the first element is index zero, so if you take a five elements subset starting at 1 for the Y values, you probably should also start at 1 for the x-values, else the x and y don't match up).
(1,796 Views)
Accepted by ManuelElze
(1,788 Views)
It seems to work just fine with the right formula.
Thank you so much. I was so focused on the wireing that I totaly missed this. Stupid me.
(1,748 Views)
