Showing results forĀ
Search instead forĀ
Did you mean:Ā
Normal string to HexaDecimal String
Dear NI
I have a problem with string conversions my problem is that i have a normal string e.g "ff002d" with size 6 bytes now i have to convert this into hexa string like this "FF00 2D" (this is anohter string whose hexa display is like this "FF00 2D" and normal display is like this "Ćæ -" ) of size with 3 bytes. Thanks in advance for your time and intrest...
regards
(10,635 Views)
Accepted by topic author mazhar.ali
(10,631 Views)
If it is always exactly 6 bytes of hex formatted number, you can also do the following.
(10,622 Views)
thanx a lot sir it works perfectly and no my string is of varriable size. so first post is my required solution.
(10,613 Views)
Isn't it great if you get a solution in less time (<3minutes) than it probably took you to compose and submit the question? šŸ˜„
(10,600 Views)
It is really great...
(10,574 Views)
