Not able to remove spaces from ASCII code Hex string
Not sure, but maybe this does the job (I removed the CRC part):
Paolo
Message 11 of 22
(3,423 Views)
here crc.vi is a subvi
Message 12 of 22
(3,420 Views)
This is giving Incorrect conversion
Message 13 of 22
(3,417 Views)
The way i have did is only giving the correct conversion as this solution was given by Mr. Altenbach he knows the datasheet of these strings
Message 14 of 22
(3,415 Views)
Here's what I would do (skipped the CRC for now)
Message 15 of 22
(3,411 Views)
But Sir Desired output is like given in this datasheet i hope you remember sir
Message 16 of 22
(3,406 Views)
As the default values are attached in the VI $ should be 24 in ASCII but using this method its not like that
Message 17 of 22
(3,404 Views)
What is "this method" and what is "that" you are comparing it to? You need to be less ambiguous!
Message 18 of 22
(3,396 Views)
Accepted by Anjaney
I do get a "24" for the $. I haven't inspected the CRC calculation, but maybe something along these lines would do what you want after some more tweaks.
Message 19 of 22
(3,395 Views)
and ir can you please help me with how it reverse will work
Message 20 of 22
(3,392 Views)
