Not case sensitive string comparison
@crossrulz wrote:
3. Why in Input List using a local variable instead of the terminal?
Because for some weird reason it is an indicator instead of a control. 😄
As has been said, here's equivalent code:
Message 21 of 23
(646 Views)
Ok, notes taken. This is part of the bigger program that I wrote back in 2019. I'm self tought so sometimes I overcomplicate things that could be made simpler. I appreciate the input 🙂
Message 22 of 23
(617 Views)
As mentioned, this was a "literal" simplification.
More elegant would be to just check if the index is non-negative. No need for the string equality.
Message 23 of 23
(609 Views)
