Number Array to Boolean Array ??
You could hold your breath along with me, but I don't think it will happen.  Darren gave a pretty good explanation.  Too much work for NI R&D for not enough benefit.  Just remember !=0.
- tbob
Inventor of the WORM Global
Message 21 of 24
(1,867 Views)
Why don't you just write a little VI with a similar icon and !=0 inside? It would not be in the functions palette, but you could put it with your own collection of handy little VIs (User Libraries?). The inconvenient thing is that none of the available connector patterns is ideal for this.
I did something similar to the =0 so that DBL that had small round off error could be determined to be approximately =0.
Lynn
Message 22 of 24
(1,857 Views)
Message 23 of 24
(1,005 Views)
@Michael_Fidler wrote:
When I see "!" I think "bang" and not "not". Now I know.
Michael J Fidler
In several text based languages != is Not equal, in some it's /= or <>. The last is probably the most correct syntactically, but the other try to emulate ≠
Qestit Systems
Certified-LabVIEW-Developer
Message 24 of 24
(997 Views)
