Numeric Array to String
I have an array of U8 data that I need to convert to a single string of numbers.
The array is quite large and I can convert to a single string of numbers by looping through the array and converting each element to a numeric string & concatenating each converted element to string.
I am wondering what is the most efficient/faster way of converting?
Thanks & Regards,
Shane.
Message 1 of 10
(23,420 Views)
Please attach your VI instead of a picture.
There are many ways to do that. What other methods have you tried? How do you measure speed?
Message 2 of 10
(23,412 Views)
If you want space padded to 3 digits, just wire the array to the primitive and insert a "concatenate string" to the output. No loop needed.
If you want zero padded to 3 digits, I would recommend a LUT if the array is large. There are only 256 different strings.
Message 3 of 10
(23,400 Views)
There is also the Array To Spreadsheet String.
Message 4 of 10
(23,376 Views)
except you would need to get rid of the delimiters later. 😄 (see also)
Message 5 of 10
(23,374 Views)
Yeah, unfortunately you can't use "Empty string" as delimiter.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 10
(23,336 Views)
/Y
Borderline bug if you'd ask me. Totally no need for it not to work.
Message 7 of 10
(23,325 Views)
So why did my idea only get 28 votes since 2009 😞
Message 8 of 10
(23,306 Views)
+1 on that. I also don't understand why my ideas don't get votes (especially my new find and replace ideas 1 and 2 (plug)).
It seems most people only watch the "hot ideas", so only few new and hot ideas ever get noted. I think it should go.
Message 9 of 10
(23,295 Views)
Yes, the IPE is a bit crippled when it comes to indexing. there is also this very old idea, of course. 😄
(But yes, ever since the page redesign, I rarely browse the ideas exchange anymore.)
Message 10 of 10
(23,288 Views)
